- // File: bulkloop.c
- // Contents: Hooks required to implement USB peripheral function.
- // $Archive: /USB/Examples/FX2LP/bulkloop/bulkloop.c $
- // $Date: 3/23/05 2:55p $
- // $Revision: 4 $
- // Copyright 2003, Cypress Semiconductor Corporation
- #pragma NOIV // Do not generate interrupt vectors
- #include "fx2.h"
- #include "fx2regs.h"
- #include "syncdly.h" // SYNCDELAY macro
- extern BOOL GotSUD; // Received setup data flag
- extern BOOL Sleep;
- extern BOOL Rwuen;
- extern BOOL Selfpwr;
- BYTE Configuration; // Current configuration
- BYTE AlternateSetting; // Alternate settings
- #define VR_NAKALL_ON 0xD0
- #define VR_NAKALL_OFF 0xD1
- // Task Dispatcher hooks
- // The following hooks are called by the task dispatcher.
- void TD_Init(void) // Called once at startup
- // set the CPU clock to 48MHz
- CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1) ;
- // set the slave FIFO interface to 48MHz
- IFCONFIG |= 0x40;
- // Registers which require a synchronization delay, see section 15.14
- // FIFORESET FIFOPINPOLAR
- // INPKTEND OUTPKTEND
- // EPxBCH:L REVCTL
- // GPIFTCB3 GPIFTCB2
- // GPIFTCB1 GPIFTCB0
- // EPxFIFOPFH:L EPxAUTOINLENH:L
- // EPxFIFOCFG EPxGPIFFLGSEL
- // PINFLAGSxx EPxFIFOIRQ
- // EPxFIFOIE GPIFIRQ
- // GPIFIE GPIFADRH:L
- // UDMACRCH:L EPxGPIFTRIG
- // GPIFTRIG
- // Note: The pre-REVE EPxGPIFTCH/L register are affected, as well...
- // ...these have been replaced by GPIFTC[B3:B0] registers
- // default: all endpoints have their VALID bit set
- // default: TYPE1 = 1 and TYPE0 = 0 --> BULK
- // default: EP2 and EP4 DIR bits are 0 (OUT direction)
- // default: EP6 and EP8 DIR bits are 1 (IN direction)
- // default: EP2, EP4, EP6, and EP8 are double buffered
- // we are just using the default values, yes this is not necessary...
- EP1OUTCFG = 0xA0;
- EP1INCFG = 0xA0;
- SYNCDELAY; // see TRM section 15.14
- EP2CFG = 0xA2;
- SYNCDELAY;
- EP4CFG = 0xA0;
- SYNCDELAY;
- EP6CFG = 0xE2;
- SYNCDELAY;
- EP8CFG = 0xE0;
- // out endpoints do not come up armed
- // since the defaults are double buffered we must write dummy byte counts twice
- SYNCDELAY;
- EP2BCL = 0x80; // arm EP2OUT by writing byte count w/skip.
- SYNCDELAY;
- EP2BCL = 0x80;
- SYNCDELAY;
- EP4BCL = 0x80; // arm EP4OUT by writing byte count w/skip.
- SYNCDELAY;
- EP4BCL = 0x80;
- // enable dual autopointer feature
- AUTOPTRSETUP |= 0x01;
- void TD_Poll(void) // Called repeatedly while the device is idle
- WORD i;
- WORD count;
- if(!(EP2468STAT & bmEP2EMPTY))
- { // check EP2 EMPTY(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is empty
- if(!(EP2468STAT & bmEP6FULL))
- { // check EP6 FULL(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is full
- APTR1H = MSB( &EP2FIFOBUF );
- APTR1L = LSB( &EP2FIFOBUF );
- AUTOPTRH2 = MSB( &EP6FIFOBUF );
- AUTOPTRL2 = LSB( &EP6FIFOBUF );
- count = (EP2BCH << 8) + EP2BCL;
- // loop EP2OUT buffer data to EP6IN
- for( i = 0x0000; i < count; i++ )
- // setup to transfer EP2OUT buffer to EP6IN buffer using AUTOPOINTER(s)
- EXTAUTODAT2 = EXTAUTODAT1;
- EP6BCH = EP2BCH;
- SYNCDELAY;
- EP6BCL = EP2BCL; // arm EP6IN
- SYNCDELAY;
- EP2BCL = 0x80; // re(arm) EP2OUT
- if(!(EP2468STAT & bmEP4EMPTY))
- { // check EP4 EMPTY(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is empty
- if(!(EP2468STAT & bmEP8FULL))
- { // check EP8 FULL(busy) bit in EP2468STAT (SFR), core set's this bit when FIFO is full
- APTR1H = MSB( &EP4FIFOBUF );
- APTR1L = LSB( &EP4FIFOBUF );
- AUTOPTRH2 = MSB( &EP8FIFOBUF );
- AUTOPTRL2 = LSB( &EP8FIFOBUF );
- count = (EP4BCH << 8) + EP4BCL;
- // loop EP4OUT buffer data to EP8IN
- // setup to transfer EP4OUT buffer to EP8IN buffer using AUTOPOINTER(s)
- EP8BCH = EP4BCH;
- SYNCDELAY;
- EP8BCL = EP4BCL; // arm EP8IN
- SYNCDELAY;
- EP4BCL = 0x80; // re(arm) EP4OUT
- BOOL TD_Suspend(void) // Called before the device goes into suspend mode
- return(TRUE);
- BOOL TD_Resume(void) // Called after the device resumes
- return(TRUE);
- // Device Request hooks
- // The following hooks are called by the end point 0 device request parser.
- BOOL DR_GetDescriptor(void)
- return(TRUE);
- BOOL DR_SetConfiguration(void) // Called when a Set Configuration command is received
- Configuration = SETUPDAT[2];
- return(TRUE); // Handled by user code
- BOOL DR_GetConfiguration(void) // Called when a Get Configuration command is received
- EP0BUF[0] = Configuration;
- EP0BCH = 0;
- EP0BCL = 1;
- BOOL DR_SetInterface(void) // Called when a Set Interface command is received
- AlternateSetting = SETUPDAT[2];
- BOOL DR_GetInterface(void) // Called when a Set Interface command is received
- EP0BUF[0] = AlternateSetting;
- EP0BCH = 0;
- EP0BCL = 1;
- BOOL DR_GetStatus(void)
- return(TRUE);
- BOOL DR_ClearFeature(void)
- return(TRUE);
- BOOL DR_SetFeature(void)
- return(TRUE);
- BOOL DR_VendorCmnd(void)
- BYTE tmp;
- switch (SETUPDAT[1])
- case VR_NAKALL_ON:
- tmp = FIFORESET;
- tmp |= bmNAKALL;
- SYNCDELAY;
- FIFORESET = tmp;
- break;
- case VR_NAKALL_OFF:
- tmp = FIFORESET;
- tmp &= ~bmNAKALL;
- SYNCDELAY;
- FIFORESET = tmp;
- break;
- default:
- return(TRUE);
- return(FALSE);
- // USB Interrupt Handlers
- // The following functions are called by the USB interrupt jump table.
- // Setup Data Available Interrupt Handler
- void ISR_Sudav(void) interrupt 0
- GotSUD = TRUE; // Set flag
- EZUSB_IRQ_CLEAR();
- USBIRQ = bmSUDAV; // Clear SUDAV IRQ
- // Setup Token Interrupt Handler
- void ISR_Sutok(void) interrupt 0
- USBIRQ = bmSUTOK; // Clear SUTOK IRQ
- void ISR_Sof(void) interrupt 0
- USBIRQ = bmSOF; // Clear SOF IRQ
- void ISR_Ures(void) interrupt 0
- // whenever we get a USB reset, we should revert to full speed mode
- pConfigDscr = pFullSpeedConfigDscr;
- ((CONFIGDSCR xdata *) pConfigDscr)->type = CONFIG_DSCR;
- pOtherConfigDscr = pHighSpeedConfigDscr;
- ((CONFIGDSCR xdata *) pOtherConfigDscr)->type = OTHERSPEED_DSCR;
- USBIRQ = bmURES; // Clear URES IRQ
- void ISR_Susp(void) interrupt 0
- Sleep = TRUE;
- USBIRQ = bmSUSP;
- void ISR_Highspeed(void) interrupt 0
- if (EZUSB_HIGHSPEED())
- pConfigDscr = pHighSpeedConfigDscr;
- pOtherConfigDscr = pFullSpeedConfigDscr;
- USBIRQ = bmHSGRANT;
- void ISR_Ep0ack(void) interrupt 0
- void ISR_Stub(void) interrupt 0
- void ISR_Ep0in(void) interrupt 0
- void ISR_Ep0out(void) interrupt 0
- void ISR_Ep1in(void) interrupt 0
- void ISR_Ep1out(void) interrupt 0
- void ISR_Ep2inout(void) interrupt 0
- void ISR_Ep4inout(void) interrupt 0
- void ISR_Ep6inout(void) interrupt 0
- void ISR_Ep8inout(void) interrupt 0
- void ISR_Ibn(void) interrupt 0
- void ISR_Ep0pingnak(void) interrupt 0
- void ISR_Ep1pingnak(void) interrupt 0
- void ISR_Ep2pingnak(void) interrupt 0
- void ISR_Ep4pingnak(void) interrupt 0
- void ISR_Ep6pingnak(void) interrupt 0
- void ISR_Ep8pingnak(void) interrupt 0
- void ISR_Errorlimit(void) interrupt 0
- void ISR_Ep2piderror(void) interrupt 0
- void ISR_Ep4piderror(void) interrupt 0
- void ISR_Ep6piderror(void) interrupt 0
- void ISR_Ep8piderror(void) interrupt 0
- void ISR_Ep2pflag(void) interrupt 0
- void ISR_Ep4pflag(void) interrupt 0
- void ISR_Ep6pflag(void) interrupt 0
- void ISR_Ep8pflag(void) interrupt 0
- void ISR_Ep2eflag(void) interrupt 0
- void ISR_Ep4eflag(void) interrupt 0
- void ISR_Ep6eflag(void) interrupt 0
- void ISR_Ep8eflag(void) interrupt 0
- void ISR_Ep2fflag(void) interrupt 0
- void ISR_Ep4fflag(void) interrupt 0
- void ISR_Ep6fflag(void) interrupt 0
- void ISR_Ep8fflag(void) interrupt 0
- void ISR_GpifComplete(void) interrupt 0
- void ISR_GpifWaveform(void) interrupt 0
上面的68013的官方examples里面的代码,对端点设置有个疑问,其中如下:
- EP1OUTCFG = 0xA0;
- EP1INCFG = 0xA0;
- EP2CFG = 0xA2;
- SYNCDELAY;
- EP4CFG = 0xA0;
- SYNCDELAY;
- EP6CFG = 0xE2;
- SYNCDELAY;
- EP8CFG = 0xE0;
- SYNCDELAY;
- SYNCDELAY;
- EP2BCL = 0x80;
- SYNCDELAY;
- SYNCDELAY;
- EP4BCL = 0x80;
这里已经将EP2设置为双缓冲区了,每个缓冲区为512Byte,那为什么下面在设置EP2BC的时候只设置了EP2BCL=0x80,而没有设置EP2BCH呢,按我的理解应该是设置两遍EP2BCH=0x02,EP2BCL=0x00这样才对呀?我在哪里理解错了吗?哪位给斧正一下,谢了。 |
