发表于 2015-7-24 16:50:37
谁能帮我解释一下,DMP的配置过程啊?
void MPU6050_DMP_Init(void)
if(!mpu_init())
/* Get/set hardware configuration. Start gyro. */
/* Wake up all sensors. */
if(!mpu_set_sensors(INV_XYZ_GYRO | INV_XYZ_ACCEL))
printf("mpu_set_sensor complete ......\r\n");
/* Push both gyro and accel data into the FIFO. */
if(!mpu_configure_fifo(INV_XYZ_GYRO | INV_XYZ_ACCEL))
printf("mpu_configure_fifo complete ......\r\n");
if(!mpu_set_sample_rate(DEFAULT_MPU_HZ))
printf("mpu_set_sample_rate complete ......\r\n");
/* To initialize the DMP:
* 1. Call dmp_load_motion_driver_firmware(). This pushes the DMP image in
* inv_mpu_dmp_motion_driver.h into the MPU memory.
* 2. Push the gyro and accel orientation matrix to the DMP.
* 3. Register gesture callbacks. Don't worry, these callbacks won't be
* executed unless the corresponding feature is enabled.
* 4. Call dmp_enable_feature(mask) to enable different features.
* 5. Call dmp_set_fifo_rate(freq) to select a DMP output rate.
* 6. Call any feature-specific control functions.
* To enable the DMP, just call mpu_set_dmp_state(1). This function can
* be called repeatedly to enable and disable the DMP at runtime.
* The following is a short summary of the features supported in the DMP
* image provided in inv_mpu_dmp_motion_driver.c:
* DMP_FEATURE_LP_QUAT: Generate a gyro-only quaternion on the DMP at
* 200Hz. Integrating the gyro data at higher rates reduces numerical
* errors (compared to integration on the MCU at a lower sampling rate).
* DMP_FEATURE_6X_LP_QUAT: Generate a gyro/accel quaternion on the DMP at
* 200Hz. Cannot be used in combination with DMP_FEATURE_LP_QUAT.
* DMP_FEATURE_TAP: Detect taps along the X, Y, and Z axes.
* DMP_FEATURE_ANDROID_ORIENT: Google's screen rotation algorithm. Triggers
* an event at the four orientations where the screen should rotate.
* DMP_FEATURE_GYRO_CAL: Calibrates the gyro data after eight seconds of
* no motion.
* DMP_FEATURE_SEND_RAW_ACCEL: Add raw accelerometer data to the FIFO.
* DMP_FEATURE_SEND_RAW_GYRO: Add raw gyro data to the FIFO.
* DMP_FEATURE_SEND_CAL_GYRO: Add calibrated gyro data to the FIFO. Cannot
* be used in combination with DMP_FEATURE_SEND_RAW_GYRO.
if(!dmp_load_motion_driver_firmware())
printf("dmp_load_motion_driver_firmware complete ......\r\n");
if(!dmp_set_orientation(inv_orientation_matrix_to_scalar(gyro_orientation)))
printf("dmp_set_orientation complete ......\r\n");
if(!dmp_enable_feature(DMP_FEATURE_6X_LP_QUAT | DMP_FEATURE_TAP |
DMP_FEATURE_ANDROID_ORIENT | DMP_FEATURE_SEND_RAW_ACCEL | DMP_FEATURE_SEND_CAL_GYRO |
DMP_FEATURE_GYRO_CAL))
printf("dmp_enable_feature complete ......\r\n");
if(!dmp_set_fifo_rate(DEFAULT_MPU_HZ))
printf("dmp_set_fifo_rate complete ......\r\n");
run_self_test();
if(!mpu_set_dmp_state(1))
printf("mpu_set_dmp_state complete ......\r\n");
