我手头有一片nucelo STM32F411RE 板子,是透过有源振荡器,osc in ,osc out (空接),然后这个振荡器是由 through STLINK MCO pin of STM32F103 microcontroller. The frequencycannot be changed and is fixed at 8 MHz.
我找不到这两个宏定义STM32F411xE,#define USE_HSE_BYPASS,这个在那边可以找的到
#if defined(STM32F411xE) /*!< Uncomment the following line if you need to clock the STM32F411xE by HSE Bypass
through STLINK MCO pin of STM32F103 microcontroller. The frequency cannot be changed
Hardware configuration needed for Nucleo Board:
?SB54, SB55 OFF
?R35 removed
?SB16, SB50 ON */
/* #define USE_HSE_BYPASS */ //这叙述为何被屏蔽掉
#if defined(USE_HSE_BYPASS)
#define HSE_BYPASS_INPUT_FREQUENCY 8000000
#endif /* USE_HSE_BYPASS */
#endif /* STM32F411xE */
