发表于 2019-5-7 22:04:42
这本来就是emwin的示例而已,直接看代码就行了!
C文件路径在Keil_v5\ARM\Segger\emWin\Sample\Tutorial\ANIMATION_Basics\ANIMATION_Basics.c
内容如下:
- * SEGGER Microcontroller GmbH & Co. KG *
- * Solutions for real time microcontroller applications *
- * (c) 1996 - 2017 SEGGER Microcontroller GmbH & Co. KG *
- * Internet: www.segger.com Support: support@segger.com *
- ** emWin V5.46 - Graphical user interface for embedded applications **
- All Intellectual Property rights in the Software belongs to SEGGER.
- emWin is protected by international copyright laws. Knowledge of the
- source code may not be used to write a similar product. This file may
- only be used in accordance with the following terms:
- The software has been licensed to ARM LIMITED whose registered office
- is situated at 110 Fulbourn Road, Cambridge CB1 9NJ, England solely
- for the purposes of creating libraries for ARM7, ARM9, Cortex-M
- series, and Cortex-R4 processor-based devices, sublicensed and
- distributed as part of the MDK-ARM Professional under the terms and
- conditions of the End User License supplied with the MDK-ARM
- Professional.
- Full source code is available at: www.segger.com
- We appreciate your understanding and fairness.
- Licensing information
- Licensor: SEGGER Software GmbH
- Licensed to: ARM Ltd, 110 Fulbourn Road, CB1 9NJ Cambridge, UK
- Licensed SEGGER software: emWin
- License number: GUI-00181
- License model: LES-SLA-20007, Agreement, effective since October 1st 2011
- Licensed product: MDK-ARM Professional
- Licensed platform: ARM7/9, Cortex-M/R4
- Licensed number of seats: -
- File : ANIMATION_Basics.c
- Purpose : Sample showing the basics of using the animation object.
- Requirements: WindowManager - ( )
- MemoryDevices - ( )
- AntiAliasing - ( )
- VNC-Server - ( )
- PNG-Library - ( )
- TrueTypeFonts - ( )
- #include <stddef.h>
- #include "GUI.h"
- * Types
- typedef struct {
- int xSize, ySize;
- int xPart, yPart;
- int xPos, yPos;
- int Dir;
- int Size;
- int ObjectSize;
- } ANIM_DATA;
- * Static code
- * _CalcPosition
- * Purpose:
- * Optional application defined position calculation in dependence
- * of the point of time within the animations timeline.
- static I32 _CalcPosition(GUI_TIMER_TIME ts, GUI_TIMER_TIME te, GUI_TIMER_TIME tNow) {
- I32 Result;
- int Diff, Pos, Modulation;
- Diff = te - ts;
- // Linear calculation
- if (Diff) {
- Result = (tNow * GUI_ANIM_RANGE) / (te - ts);
- } else {
- Result = GUI_ANIM_RANGE;
- // Modulation
- Modulation = GUI_ANIM_RANGE >> 3;
- Pos = Result / Modulation;
- Result -= Modulation * Pos;
- if (Pos & 1) {
- Result = Modulation - Result;
- Result = (Result * Result) / Modulation;
- } else {
- Result += Modulation * Pos;
- return Result;
- * _SliceInfo
- * Purpose:
- * Called before the first and after the last animation item of one
- * 'slice' is drawn. A 'slice' means one or more animation item
- * which need to be drawn at a determined point in time.
- * That mechanism is used here to avoid flickering.
- static void _SliceInfo(int State, void * pVoid) {
- GUI_USE_PARA(pVoid);
- switch (State) {
- case GUI_ANIM_START:
- GUI_MULTIBUF_Begin();
- break;
- case GUI_ANIM_END:
- GUI_MULTIBUF_End();
- break;
- * _PrepareDrawing
- * Parameters:
- * pInfo - Animation information passed by emWin to the application
- * pVoid - Application defined void pointer
- * ppData - Data (pointer) pointer to application data
- * xPosOld - Position to be used for clearing the display
- * Index - Index of animation
- static void _PrepareDrawing(GUI_ANIM_INFO * pInfo, void * pVoid, ANIM_DATA ** ppData, int xPosOld, int Index) {
- ANIM_DATA * pData;
- // Use custom void pointer for pointing to application defined data structure
- pData = *ppData = (ANIM_DATA *)pVoid;
- // Calculate x-position in dependence of current animation value
- switch (pData->Dir) {
- case +1:
- pData->xPos = pData->xPart + ((pData->xSize - pData->xPart * 2) * pInfo->Pos) / GUI_ANIM_RANGE;
- break;
- case -1:
- pData->xPos = pData->xSize - pData->xPart - 1 - ((pData->xSize - pData->xPart * 2) * pInfo->Pos) / GUI_ANIM_RANGE;
- break;
- // Calculate object size in dependence of position
- pData->ObjectSize = (pData->Size * pInfo->Pos) / GUI_ANIM_RANGE;
- // Calculate y-position in dependence of animation index
- pData->yPos = pData->yPart * (2 * Index + 1);
- // Clears the area of the previous drawing
- if (xPosOld) {
- GUI_ClearRect(xPosOld - pData->yPart, pData->yPos - pData->yPart, xPosOld + pData->yPart, pData->yPos + pData->yPart - 1);
- // Set item color in dependence of animation state
- switch (pInfo->State) {
- pData->Dir = ((((pData->Dir + 1) / 2) ^ 1) * 2) - 1;
- //lint -fallthrough
- GUI_SetColor(GUI_RED);
- break;
- case GUI_ANIM_RUNNING:
- GUI_SetColor(GUI_GREEN);
- break;
- * _AnimDrawCircle
- static void _AnimDrawCircle(GUI_ANIM_INFO * pInfo, void * pVoid) {
- static int xPosOld;
- _PrepareDrawing(pInfo, pVoid, &pData, xPosOld, 0);
- GUI_DrawCircle(pData->xPos, pData->yPos, pData->ObjectSize);
- xPosOld = pData->xPos;
- * _AnimDrawRect
- static void _AnimDrawRect(GUI_ANIM_INFO * pInfo, void * pVoid) {
- _PrepareDrawing(pInfo, pVoid, &pData, xPosOld, 2);
- GUI_DrawRect(pData->xPos - pData->ObjectSize, pData->yPos - pData->ObjectSize, pData->xPos + pData->ObjectSize, pData->yPos + pData->ObjectSize);
- * _AnimFillCircle
- static void _AnimFillCircle(GUI_ANIM_INFO * pInfo, void * pVoid) {
- _PrepareDrawing(pInfo, pVoid, &pData, xPosOld, 1);
- GUI_FillCircle(pData->xPos, pData->yPos, pData->ObjectSize);
- * _AnimFillRect
- static void _AnimFillRect(GUI_ANIM_INFO * pInfo, void * pVoid) {
- _PrepareDrawing(pInfo, pVoid, &pData, xPosOld, 3);
- GUI_FillRect(pData->xPos - pData->ObjectSize, pData->yPos - pData->ObjectSize, pData->xPos + pData->ObjectSize, pData->yPos + pData->ObjectSize);
- * _AnimDrawCross
- static void _AnimDrawCross(GUI_ANIM_INFO * pInfo, void * pVoid) {
- _PrepareDrawing(pInfo, pVoid, &pData, xPosOld, 4);
- GUI_DrawHLine(pData->yPos, pData->xPos - pData->ObjectSize, pData->xPos + pData->ObjectSize);
- GUI_DrawVLine(pData->xPos, pData->yPos - pData->ObjectSize, pData->yPos + pData->ObjectSize);
- * _SetupAnimationData
- static void _SetupAnimationData(ANIM_DATA * pData) {
- // Get display size
- pData->xSize = LCD_GetXSize();
- pData->ySize = LCD_GetYSize();
- pData->xPart = pData->xSize / 10;
- pData->yPart = pData->ySize / 10;
- pData->Size = (pData->yPart * 4) / 5;
- pData->Dir = 1;
- * _AnimCreate
- static void _AnimCreate(ANIM_DATA * pData) {
- GUI_ANIM_HANDLE hAnim;
- // Create animation object
- // Remark: The min time/frame here is 100 to be able to notice
- // the colors. In a real application this value should
- // be significantly smaller to ensure a smooth motion.
- // Slice callback routine --------------+
- // Custom *void pointer --------+ |
- // Minimum time per frame --+ | |
- // Duration ----------+ | | |
- hAnim = GUI_ANIM_Create(4000, 50, pData, _SliceInfo);
- // Add animation items
- // Animation routine to be called ----------------------------+
- // Custom *void pointer ---------------------------+ |
- // Method of position calculation + | |
- // End on timeline ---------+ | | |
- // Start on timeline -+ | | | |
- GUI_ANIM_AddItem(hAnim, 0, 2000, ANIM_ACCEL, pData + 0, _AnimDrawCircle);
- GUI_ANIM_AddItem(hAnim, 500, 2500, ANIM_DECEL, pData + 1, _AnimDrawRect);
- GUI_ANIM_AddItem(hAnim, 1000, 3000, ANIM_ACCELDECEL, pData + 2, _AnimFillCircle);
- GUI_ANIM_AddItem(hAnim, 1500, 3500, ANIM_LINEAR, pData + 3, _AnimFillRect);
- GUI_ANIM_AddItem(hAnim, 2000, 4000, _CalcPosition, pData + 4, _AnimDrawCross); // Item with custom defined position calculation
- // Start animation
- // Function to be called on animation delete --+
- // Num loops ------------+ |
- // Animation ------+ | |
- GUI_ANIM_StartEx(hAnim, -1, NULL); // -1 means endless loop
- * Public code
- * MainTask
- void MainTask(void) {
- ANIM_DATA aData[5];
- int i;
- GUI_Init();
- // Initialize some data used for drawing operations
- for (i = 0; i < (int)GUI_COUNTOF(aData); i++) {
- _SetupAnimationData(&aData[i]);
- // Create animation and pass pointer to user data and animation context
- _AnimCreate(aData);
- // Keep alive...
- while (1) {
- GUI_Delay(100);
- /*************************** End of file ****************************/
复制代码 |
