发表于 2011-12-6 16:02:24
(原文件名:1.jpg)
数据格式你得自己转换一下:
File
This is used to drive a circuit from an analogue signal that is specified by a series of time points and data values contained in an ASCII file. The ASCII file should be formatted with one time/voltage pair on each line seperated by white space (spaces or tabs , not commas ). The time values must be in ascending order and all values must be simple floating point numbers ( no suffixes allowed ).
Example
The following example data file produces three cycles of a saw-tooth waveform with rise time 0.9ms, fall time 0.1ms and amplitude 1V.
0 0
9E-4 1
1E-3 0
1.9E-3 1
2E-3 0
2.9E-3 1
3E-3 0
Audio
This is used to drive a circuit from a Windows WAV file. In conjunction with Audio Graphs they make it possible to hear the results of processing a sound signal through a simulated circuit. |
